RCU Forums - View Single Post - XYZ 26 CC ENGINE
Old 09-01-2009 | 05:52 AM
aussiesteve's Avatar
aussiesteve
Default RE: XYZ 26 CC ENGINE
I'm not familiar with the exact intricacies of the XYZ but if it is like most engines, Undo the Crank extension (There is most likely a nut inside the front of the prop hub - use a long reach socket) and then the hub will either come off easily or you may need to use a small puller to remove it.
MOST engines need work after flying to below ground level.
