XYZ 26 CC ENGINE
Old 08-31-2009 | 01:49 PM
Default XYZ 26 CC ENGINE
I dove and dident stop, now my engine needs some work. How do you take off the prop hub? I just read that this is normal for a xyz engine bent crank soft?
HELP
Old 09-01-2009 | 05:52 AM
aussiesteve's Avatar
Default RE: XYZ 26 CC ENGINE
I'm not familiar with the exact intricacies of the XYZ but if it is like most engines, Undo the Crank extension (There is most likely a nut inside the front of the prop hub - use a long reach socket) and then the hub will either come off easily or you may need to use a small puller to remove it.
MOST engines need work after flying to below ground level.
