RCU Forums - View Single Post - Engine thrust angles
Old 09-03-2009 | 03:07 AM
pdillon's Avatar
pdillon
Default RE: Engine thrust angles
The info you gave leads me to question my own build in progress. I'm building a Sr Telemaster,w/Fuji BT50SB engine its for towing.Well the down/right angles change from the stock position given on the plans?The engine is bigger & weights more than required. Thank You Phil
