ORIGINAL: skillet92
Guys I would like to know if the dl50 will decently power a 18lb plane. I ask because I have a DL 50 on a GP 330S and it is just to small and light. But it is around 15lbs and I 3D fly. If I get a true 30 percent that is in the 17 to 18 lb range is the DL going to still pull it straight up???
NP
All Extreme Flight 30% planes weigh in from 17-1/2lbs, about 18lbs with tuned pipe over stock muffler setup. Either combo flies fine.
