RCU Forums - View Single Post - YS63 question / problem
Old 09-03-2009 | 11:31 PM
tadawson
Default RE: YS63 question / problem
ORIGINAL: Nitrodan73
I too am having problems with my 63 s running pretty good at half or quarter throttle and then when I advance the throttle, it wants to die. If I go from Idle to full throttle, It will go at first but then die. I can't even get the high end set because it won't stay there for long. I just got it back from YS service so it should run great. Shouldn't it?
Have you verified that your check valve and tank plumbing is correct, and that the tank is getting pressurized? That's about the only variable between your setup and when YS test ran it . . .
- Tim
