I have just received the first of a limited pre-production run of Nutech Racings Thunderbolt II Pro Race Version. This version is only available to distributors and selected racers, this was sent pre-assembled for now but the factory tell me they will come as a kit version once production begins! These will be available with or without CY engines. I choose without as I will be fitting a modified Zenoah 4 bolt 26cc.
Here is the list of spec's for the car but these may or will be changed before production units!
Specifications of the Racing verison:
CNC suspension arm Front/ Rear Lower
CNC Center diff mount
Lightened main gear set
Stainless steel rear upper Turnbuckle,
Stainless steel steering turnbuckle
Stainless steel front upper turnbuckle
CNC roll cage bar
Lightened wheel Axle
Lightened center diff outdrive cup
Lightened outdrive cup
Lightened drive cup
CNC suspension arm front upper
CNC suspension arm rear upper
CNC steering servo saver set
CNC 7075 Ackerman Rod
CNC 7075 front/ rear shock tower
CNC upper suspension holder
CNC C-hub
CNC servo mount
CNC engine mount
CNC flywheel holder
CNC rear wheel stub
CVD
CNC fuel tank cap
CNC diff gear box
CNC servo horns
Lightened clutch bell
Lightened center dog bone front/rear
Wheels with PE inner foam.
I will let the pictures do the talking for now and will update as I go through it and build.
