ORIGINAL: Valve floater
Jodi
I run mc-1 bel-ray at 50-1. I have seen that HR-1 is made for dirt bikes in dusty conditions. It contains additives that clean the engine. But you say you prefer it? I may use it next time. What are your findings based on? Can i run HR-1 at 50-1 also. It calls for diff. ratio`s on both oils. Also, i went back to the stock plug, i see no diff. in power. Findings? Thanks
The H1R power valve formula has a more powerful detergent package that keep the engine cleaner inside, I'd mix it at 40:1. Bel-Ray is good stuff.
