RCU Forums - View Single Post - DL-50 engine
Thread: DL-50 engine
Old 09-04-2009 | 01:22 PM
  #5476
jedijody's Avatar
jedijody
Default RE: DL-50 engine
ORIGINAL: thevirginian
ACF, I wouldn't necessarely count too much on a new plug as there could be an issue with the reed valve. The standard plug is crap but it is usable for a while, at least. If the engine starts and quits after a few seconds, it is, most likely, a problem with the fuel supply. If the carb is O.K., then there is only one other component, that could be the culprid: the reed valve.
My advice and comments are based on recent experiences with this engine and the CDI module, never seen a single DL with a reed problem right out of the box. If it had one I would think it would have a hard time getting fuel to the carb, doesn't seem like the case here based on the ACF's description.
