RCU Forums - View Single Post - Four Star 60 ailerons thickness
Old 06-28-2003 | 11:46 PM
PDF
Default Four Star 60 ailerons thickness
Hello,
After fitting the hinges between the wing and the ailerons, I see a thickness difference of approx 1/8 th inch difference between the trailing edge of the wing and the leading edge of the aileron. The trailing edge of the wing is a little over 1/4 inch and the leading edge of the aileron is 3/8 th inch. Do all these kits come like this ? If so does everybody leave it alone, or do you sand it to match the trailing edge of the wing. Or does everybody leave it alone, and how would it affect flight. Thanks in advance.
Regard,
Pat
