PULAN 26ccm EI Conversion
I have a converted 26 ccm Pulan engine with the BCMA ignition kit installed.
I can not get the engine to run.
Here is the problem:
Everything hooked up properly ( incl. 4.6 volt 2400 m/amp battery)
also the magnet installed according to manufacturer's (the RED end is the NORTH POLE)
and has been installed out.
I can not get a spark!
When I r e m o v e the metal gear clamp with the sensor from the engine - I hold the clamp
in my hand and swipe it over the magnet - and I get a spark each and every time.
I install the metal clamp with the sensor with the same result as above: NO spark.
Any suggestions? What could be the problem?
