RE: PULAN 26ccm EI Conversion
Check the wires to ground with an ohm meter. There should be no continuity on the red and white leads.
Mark the sensor bracket at the center of the sensor chip. Install the sensor so it is centered on the magnet. Set air gap to 010-015. Make SURE that it doesnt touch the hub/magnet.
