RCU Forums - View Single Post - Another Shockwave 36 FE conversion.
Old 09-07-2009 | 04:44 PM
brodjack
Default RE: Another Shockwave 36 FE conversion.
Managed to finish this boat tonite,easy build.
My water jacket from Etti came the other day,it was that what was the hold up.
Going to try it with a new sharpened and balanced x442 at weekend.
It balances perfectly at 33%.the hull is totally water tight after a bath test,
The only thing i should have done is mount the motor a bit further forward,the angle of the stuffing tube and my mount wouldnt let me drill the water nipples on the jacket in the correct place,ie 1 up,1 down.The bottom nipple wouldnt fit without touching the hull.
It will be ok i think..Also it it would have allowed me to use a longer flexshaft and stuffing tube,enabling a good piece of silicone tubing on the flex tube,reckon a fair bit of water will come up the tube on the lake[] I can possibly redo it after a trial run.
I also removed the left turnfin and adjusted the right the proper angle,we Brits mainly do right turns on clockwise circuits[8D]
it wont be no speed demon,but reckon a good 40mph which is as fast as our nitro version.Its a fair bit heavier than nitro,but we always thought the nitro one was too light and flighty in the rougher water.
It will be a good long run time boat for my 12yr old son.
I'll get some video..
Brod..
ID:	1270676   Click image for larger version
ID:	1270677   Click image for larger version
ID:	1270678   Click image for larger version
