RE: DL-50 engine
If the ignition is set at 28-30 btdc, do not retard the ignition. Your engine performs best when spark timing works in conjunction with port timing. The gas octane has no effect here. The higher octane delays detonation, but only effectively in high compression engines. Trust that you do not have a high compression engine.
