Great Planes Sequence F3A
The Great Planes [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXWWM1&P=ML]Sequence F3A[/link] is an Almost-Ready-to-Fly 50" class E-Performance XLC Series Airplane. It features a balsa and plywood frame with a pre-built plywood motor box. The two-piece wings are connected with a carbon joiner. The ailerons are factory-hinged and the rudder uses a pull-pull system for control authority. The Sequence comes complete with wheels, canopy, wheel pants, pre-built motor box, decals and a 24-page instruction manual loaded with photos and detailed steps for a quick assembly.
Features:[ul][*] Balsa and plywood construction with prebuilt plywood motor box[*] Two piece wing with carbon wing joiner[*] Pull-pull rudder control system[*] Dual servo aileron control, factory hinged[*] Painted fiberglass cowl and wheel pants[*] Canopy magnetically attaches to fuselage[*] Covered in six colors of Top Flite MonoKote[*] Two piece painted fiberglass main landing gear with tailwheel wire[*] Foam wheels, main 2.25" (56mm), tailwheel .75" (19mm) diameter[*] Spinner: 2" (51mm) diameter, white in color (included)[*] Ready to fly in 4-6 hours
[/ul]Specifications:[ul][*] Wingspan: 50" (1270mm)[*] Wing Area: 505 sq in (32.6 sq dm)[*] Wing Loading: 16-17 oz/sq ft (49-52 g/sq dm)[*] Length: 51.5" (1310mm)[*] Weight: 3.5 - 3.75 lb (1590 - 1700 g)[*] Center of Gravity (CG): 4-7/8" (124mm) back from the leading edge of the wing measured at the fuselage
[/ul]
