RE: Ultra Stick ARF Vertical Stablizer
A flyer at the field has your same plane 40 size ultra stick. He had the same problem with his vertical stab. He did not try fixing it and it flyes very well the way it is. You may have to do a little trimming on your first flight but you should be able to do it with your radio. Good luck...
