RCU Forums - View Single Post - kit vs ARF
Thread: kit vs ARF
Old 09-11-2009 | 12:54 PM
Charlie P.'s Avatar
Charlie P.
Default RE: kit vs ARF
ORIGINAL: alexedit
Hi - what is the difference between a kit and an ARF - doesn't the kit come all in pieces?
I am looking for a second plane to buy - something like the tower Kaos - best plane I've ever owned.
Pieces? Some have relatively few pieces until you start sawing up the wood. The good kits come with sticks, planks, blocks and maybe (if you're lucky) some plywood. All in uncut dimensions.
We've gotten spoiled with laser cut pieces. Used to was a large number of the die cut parts were damaged and needed to be [re]made as you went.
One of my favorite builds was the Contender 60 where you get to carve the nose from large balsa blocks. Neat stuff!
Check out the sectioned Stearman wing. Even the real ones had scads of itty bitty wood pieces.
ID:	1273015   Click image for larger version
ID:	1273016   Click image for larger version
