RCU Forums - View Single Post - GP Extra 300S 60 Build
Old 09-12-2009 | 07:59 AM
  #63
RICKSTUBBZ's Avatar
RICKSTUBBZ
Default RE: GP Extra 300S 60 Build
ORIGINAL: Andrewmc
....... but to rectify the fuselage sides I have to do either one of two things;
1. Sand the fuselage sides to be parallel to the fuselage bottom. This will reduce the thickness of the ply sides around former 10 by about 0.5mm (1/32'') each.
2. Leave as is and fill the gap between the fuselage sides and the fusleage bottom with micro balloons and sand to suit
Either is easy to do but just trying to guage what other kit builders would do.
Andrew
It ain't (a little Texas draw for ya) going to be worth much. But, here is what I would do on the edges. I would either take a piece of small square balsa and fill the edge and then resand to taste or use some lightweight "spackling" to fill and then sand. Epoxy and microballons would work as well.
Peronally I like rounding all those sharp corners anyway. The thin plywood may cause a problem for me on this one.
Good Luck
