RE: Engine Mount question
If the 3 big screws are used to attach a square 1/4 plate to the front of your engine, they will have to come out to remove that plate. Once it's off the mount will go on and you will reuse those 3 screws to attach it to your engine. If you leave that thick plate on your starter cogs will not engage as they will be too far away from the crankshaft. Hope this helps.
