RCU Forums - View Single Post - Great Planes Sequence F3A
Old 09-13-2009 | 07:57 AM
Greg Covey's Avatar
Greg Covey
Default RE: Great Planes Sequence F3A
The horizontal stabilizer is glued in place with 30-minute epoxy after first installing the wings to check the alignment. The manual has good photos that detail the key alignment measurements needed. An elevator joiner wire is also installed with the stabilizer. The stabilizer covering comes pre-cut on the areas to be glued so there is no chance of weakening the surface with a razor knife.
After the glue dries on the stab, the elevators are glued to the joiner wire with epoxy and the three hinges on each elevator are secured with thin CA. I installed the elevators when gluing on the stab, as suggested in the manual, to help create a perfect alignment between the stab tips and elevators on each side.
ID:	1274145   Click image for larger version
