RE: Plettenberg Xtra 30-10 EVO - Jeti 99 and Brake
I have:
BrakeManual Setting
Dead Time0.2 secs
Initial Brake30%
End Brake-40%
Brake Speed-0.5 secs
(with the same set-up, or with APC21X14)
This is not too bad for landings, so long as you remember to blip the throttle if things become a little slow....
I fly with this setting, but have a separate throttle curve on a switch-with the same curve, except at the bottom of the stick travel.
There, I have the lowest number above zero(where the brake operates), which will maintain the slowest possible idle.
This reduces the landing workload if needed.
