RCU Forums - View Single Post - ENGINE RUNNING BACKWARDS?
Old 09-15-2009 | 11:24 AM
bruce88123
Default RE: ENGINE RUNNING BACKWARDS?
ORIGINAL: Live Wire
You never said which carburator you have. can you take a pic. of the motor and then we can tell. They put out the standard and the pumped engine and the carb's are different.
Larry K
There were a variety of carbs offered on the non-pumped engines including Perry carbs. Perry carbs were also used on the pumped engines but were a larger bore I believe and a couple of different ones were offered.
http://www.mecoa.com/kb/ is the present manufacturer and "authority" these days and could help you sort out the engine if it comes down to that point.
Current Perry pumps and carbs can be found at http://www.perrypumps.com/prod01.htm
