RCU Forums - View Single Post - Great Planes Sequence F3A
Old 09-15-2009 | 06:15 PM
Greg Covey's Avatar
Greg Covey
Default RE: Great Planes Sequence F3A
The elevator servo is mounted next on the far right side of the tail mounting servo rails. The position shown is used for proper balancing when using the recommended power system that I am using. An aft position is also available to help offset tail ballast when using a heavier motor or battery pack.
I used some silicone lubricant spray to remove the sticky tape reside from the long elevator pushrod. It had been secured in the box with tape for shipping. The pushrod is cut to length and the servo end is bent 90 degrees. Both ends are secured with supplied keepers. The control horn screws, like in the ailerons, are not visible from the top side of the model.
ID:	1276136   Click image for larger version
