RE: Seagull PC-9 Build advice please
Stix - What servos and receiver you use could depend upon what you might have in mind later down the road. I used the Hitec Supreme II receiver and Hitec or Futaba standard servos worked fine on mine. If you have more ambitious plans, by all means purchase digital servos with metal gears and more power that would be suitable for a larger, more powerful model down the road, but the Futaba S3004 or Hitec H325 or H425 servo that comes with their radios will work fine, as will the standard servo that comes with the Spectrum 7 channel radio. This model does not have oversized control surfaces and is not a 3D model, and it is a 45 sized model, so the standard carbonite geared servo will work quiet well. In fact, I used the servos that came with my Futaba Skysport 6 radio (S3004).
"Experience is a hard teacher. She always gives the test first and the lesson some time later!"
