ORIGINAL: NM2K
The Tower Hobbies .46 and the Super Tigre GS-40 are about the same size and weight. Power wise, I doubt that there is much difference. The ST GS-40 is a pretty hot engine after a rich break-in of several tanks of fuel. Both are great engines and both will pull your Cub around at more than scale speed, so don't be afraid to throttle back a bit. Your flight will last longer and you won't be beating up your model as much with the increased aerodynamic pressure that full throttle operation imparts.
Ed Cregger
Actually there is quite a bit of difference.
The GS-40 is fine, but it is not the stump puller that the TH .46 is.
