 choosing a 2 stroke/4 stroke >
Old 09-17-2009 | 10:08 AM
DenverJayhawk's Avatar
Default RE: choosing a 2 stroke/4 stroke
ORIGINAL: SushiSeeker
ORIGINAL: DenverJayhawk
I know lots of people say don't over power your model, but having done it, I can honestly say it's the most fun you can have legally.
I respectfully disagree. There is more to overpowering a model than just adding a bigger engine. The bigger engine throws a bigger prop and needs more ground clearance. Also you have to add a larger fuel tank as the larger engine will consume more fuel than a smaller engine generating the same thrust. I've done this, too but you are inviting catastrophic failure. My U-Can-Do 40 has an OS .65 because I read similar comments and as a result the plane is waaaaay over powered. She will accelerate in a vertical climb and outfly the large control surfaces causing significant flutter.
To the topic of this post, everyone has their favorite engine as do I and few people have bad things to say regarding OS Max. When my son steps out of his trainer, we will likely go with a Big Stick 40 with an OS .72 4-stroke which has the same HP rating as an OS .46.
I agree with the bigger prop issue but it is easily resolved by adding larger diameter wheels or longer landing gear. If the prop is properly balanced , you shouldn't have that much flutter. I also am using the stock fuel tank with the kit and I'm still able to get 15 min flights. I'd bet it could go even longer, but I generally set up landing at the 12-14 min mark.
These are small prices to pay for the added benefit of power.
Old 09-17-2009 | 11:05 AM
opjose's Avatar
ORIGINAL: NM2K
The Tower Hobbies .46 and the Super Tigre GS-40 are about the same size and weight. Power wise, I doubt that there is much difference. The ST GS-40 is a pretty hot engine after a rich break-in of several tanks of fuel. Both are great engines and both will pull your Cub around at more than scale speed, so don't be afraid to throttle back a bit. Your flight will last longer and you won't be beating up your model as much with the increased aerodynamic pressure that full throttle operation imparts.
Ed Cregger
Actually there is quite a bit of difference.
The GS-40 is fine, but it is not the stump puller that the TH .46 is.
Old 09-17-2009 | 11:46 AM
think i will go for a four stroke for my ugly stik .40 - .60 - just need to decide .70 .52 or maybe saito .65 - any thoughts?
Old 09-17-2009 | 12:05 PM
will an OS70 be too powerfull?
Old 09-17-2009 | 04:23 PM
saito .72 would be about right
once you go 4stroke, ya never go back.....
well almost never
have a ST 90 on a Seagull .75 extra that i love burning holes in the sky with
no 3D just a little light aerobatics...and such
Old 10-28-2009 | 07:34 AM
  #31
MaxAdventure's Avatar
My Feedback: (7)
ORIGINAL: scottm50
Saito .65 is a very old engine. I see quite a few of them come up for sale - so not hard to find, however I suspect a newer engine will probably run better for you. I have a Saito .65 I run in a Great Planes cub on floats at 5,600 MSL. I love my .65, but it can't always get that cub off the water.
Old 10-28-2009 | 09:50 AM
  #32
GaryHarris's Avatar
I wouldnt leave the Magnum 4 strokes of this deal.
Old 10-29-2009 | 04:05 PM
  #33
The Magnums work great.  And they are priced much more reasonably than other brands.  Personally I cannot justify paying OS prices when I get great performance from Magum for 100 to 150 less for a .72 to .91 size 4 stroke.
Old 10-29-2009 | 04:28 PM
  #34
GaryHarris's Avatar
I have a Magnum .52 coming out of a LT-40 and going into a Four Star 40 that I'm building now. I also have a Saito 100 that I'm currently flying with in my Four Star 60. I mean a Saito is a Saito, but I prefer the Magnum over the Saito for 3 reasons.
1: The price.
2: It sips fuel.
3: It's clean.
I like Saitos over Magnums because I think they sound better, look better and have a better mid range.
Old 10-29-2009 | 08:02 PM
  #35
rc airplane nut's Avatar
All I can say is don't get an MDS. I have an MDS .48 2-stroke in my Ultra Stick and have nothing but trouble with it.
