Ihad the same issue on same model, it would recoil fine unless you pull the rope to max distance.. Basically the spring is binding up because it is wound up too tight. If you unloop the rope until it recoils but not all they way, and then add just one loop, it should fix the problem. To unwind loops, pull the rope out a foot, hold the spool to keep it from recoiling, then push the rope back in and grab the loose rope inside.
ORIGINAL: garhdsn
I just acquired a ryan 265 this weekend. The recoil on the starter doesn't work. When pulled it doesn't recoil. When I disassemble it, and manually wind the rope on the spool and test it it pulls and recoils just fine. After assembly, i tpulls, binds up and will not recoil. Any thoughts</p>
Thanks,</p>
gary</p>
