RE: Super Kaos help
Hey David, I thought you would be building.
The wing actually fits good, it's just set in the saddle without snugging it up. It's the gap in the back that puzzles me.
I'll fill it with solid balsa, strip the center part of the wing the with of the fuselage and about 3" long, mount either bass or plywood where the wing bolts go, glue a balsa block to the bottom of the wing, feather it into the wing bolt locations and the block in the back, drill and tap (or inserts, I have both) cover and be done with it.
I was just wondering if the plans showed that you would end up with a gap if you didn't put another piece in.
Anyway, as long as I know it is typical to have a gap that needs to be filled I can continue.
Photos to come.
