ORIGINAL: blackrain
if you can do the xxl gears to the tranny for higher top speed
That's a nice looking truck.. And yes, the XXL gearing is awesome..
For bashing, just leave it as is. You'll be good to go. I assume the LST2 upgrade kit comes with 20mm hexes and the 20mm rims/tires? LST2 wheels are really heavy.. More torque would be more like adding an LRP Spec 3 to the list.. But then you're starting to get to the point where it would make the most sense to just find a new LST2 - or even the XXL.. I believe the XXL can be had for less than 600.. Check out losipartshouse.. (Need to put stuff in your cart..)
