RCU Forums - View Single Post - GP Extra 300S 60 Build
Thread
09-19-2009 | 03:13 AM
67
Andrewmc
Jul 2004
579
Cape Town, SOUTH AFRICA
RE: GP Extra 300S 60 Build
Bolted the wing to the fuselage and leveled it up then checked the incidence.
left Hand Root 0deg
Left Hand Tip 0deg
Right Hand Root 0 deg
Right Hand tip -1/2 deg
The RH tip does not concern me at this stage as very little pressure is required to rotate it to 0, so I should be able to correct this after covering without too much trouble.
I am at the point now where I need to install the control surface control rods. I want to use a Pull Pull for the rudder and to this end I have purchased the Du Bro 4/40 set.
I have never installed a pull-pull system before and wondering if I should wait untill the fin and rudder are installed before fitting the cables? Should I run the cables in the tubes provided or not?
If the cables do not run in the tubes how do you do the fuselage exit?
Reply
Like
Andrewmc
View Public Profile
Send a private message to Andrewmc
Find More Posts by Andrewmc
View iTrader Profile
