ORIGINAL: TRXRUSTLER
you should develop some software that you plug your RC's ESC into that tells you all the diagnostics of your run, like temps, top speed, amp draw, and battery specs. Pretty much like an all in one program that does it all. If not then what are some programs you have already developed?
It's called telemetry. Spektrum makes it and it does top speed/rpm's, temp, and receiver battery voltage.
