RC Software....
Old 09-20-2009 | 01:14 PM
Default RC Software....
Hey guys, I work as a software developer and sometimes I develop little small software for my personal use. Since I'm in RC.
Maybe there is something I can develop. Not sure what to develop yet. I need some ideas, maybe something that you guys need or anything. Something not too big that I can write when I'm off work. Not RC games because I don't have too much experience in developing games.
Old 09-20-2009 | 01:39 PM
Default RE: RC Software....
You should focus on tools for RC for the iphone..
Tools that you can use at the track etc..
Old 09-20-2009 | 07:14 PM
TRXRUSTLER's Avatar
My Feedback: (7)
you should develop some software that you plug your RC's ESC into that tells you all the diagnostics of your run, like temps, top speed, amp draw, and battery specs. Pretty much like an all in one program that does it all. If not then what are some programs you have already developed?
Old 09-20-2009 | 07:52 PM
Chris_RC's Avatar
ORIGINAL: TRXRUSTLER
It's called telemetry. Spektrum makes it and it does top speed/rpm's, temp, and receiver battery voltage.
Old 09-20-2009 | 08:11 PM
HJJFFFAA's Avatar
Data collection from the ESC would require enough memory installed on the ESC not to mention hall sensors, etc...It's not something you could program in. Custom firmwares for the ESC's would be cool though. Even just something that allows you to add your own code to the programming. IMO of course.
Old 09-21-2009 | 07:37 AM
Troopermanaic's Avatar
My Feedback: (7)
ORIGINAL: HJJFFFAA
they would charge over $1000 for that. Even know mp4 players from china only cost about $30 buks and are WAY more advanced then escs they still overprice them because people buy it.
Old 09-21-2009 | 12:18 PM
The Hedgehog's Avatar
They have eagle tree data loggers that do a lot of what was mentioned, at more than 10 times less than a grand.
Old 09-21-2009 | 01:48 PM
DaveG55's Avatar
Just throwing some ideas out there;
A maintenance log - it could even show tools and supplies needed, show maintenance intervals,
A spare parts inventory
A set up log/database (gearing, suspension, etc)
A program to extrapolate performance - enter in certain real time data and have a program that could predict top speed, over steer/under steer etc based on changes to gearing, motor, spring rate, etc.
A program that would aid in tuning - this would require accelerometers, temp sensors and maybe something to register the amount of smoke in the exhaust
