RE: Accu-Cycle Elite Problems
Do you have the Elite programmed for the battery and the number of times you want the battery cycled? Once you have the Elite programmed for your 600mah 4.8 Nicd press the cycle button. If your using the default settings the cycling will take a good number of hours. I usually cycle overnight or when I am not expecting to use the airplane.
