RCU Forums - View Single Post - Exceed RC F-35 battery question
Old 09-23-2009 | 11:05 AM
opjose's Avatar
opjose
Default RE: Exceed RC F-35 battery question
If I remember correctly that plane comes with an 1800mAh battery pack although the 1300mAh pack is what is listed, if memory serves me correctly ( note I MAY be wrong! ).
Even the included battery tends to run very warm to hot, so NO your existing pack will likely burn out.
I've flown this plane with a 2200mAh 20C pack after enlargening the battery cage ( removing the "bottom", not the hatch itself ).... and this was just about right... however an 1800mAh 20-25C pack seems to be the best combination between weight, speed and flight times.... ( about 5-8 minutes ).
