RCU Forums - View Single Post - Nitro models pusher Bobcat?
Old 09-24-2009 | 05:23 PM
  #3862
chuckie099's Avatar
chuckie099
Default RE: Nitro models pusher Bobcat?
<div>Hi Guys,</div><div>Got the engine back on with the smoke muffler fitted, its not a neat as I would of liked and I&rsquo;m not rally happy with the pre-heater. I have ordered some 1/8&rdquo; soft copper brake line as I have read this can be coiled much tighter than the brass tubing that I made the pre-heater with. If this is the case I will redo it as I would like to get another couple of coils around the exhaust to give the smoke oil the best chance of vaporising&hellip;and tight coils will look better.</div><div></div><div>Next jobs are to refit the fuel tank, this will need to go &frac12;&rdquo; further forward of the original position and will need a mounting plate. Then fit the oil tank, the smoke valve &amp; servo, filler and vent lines for the oil tank, a needle valve for flow control and squeeze the receiver in somewhere.</div><div></div><div>More to follow, hopefully with a test vid&hellip;</div><div></div><div>Chuck</div>
ID:	1281409   Click image for larger version
ID:	1281410   Click image for larger version
ID:	1281411   Click image for larger version
