Locking mid. diff.
Ok so your getting more power to the fronts.
Well an open differential will give more power to the side that spins easiest.
IF nothing is blocking the rear side.. then something is definitely up.
If you hold the car in your hand and give it gas.. does the rear turn at the same rate as the front wheels?
ram
