RCU Forums - View Single Post - Custom Piston Rings
Old 09-25-2009 | 06:42 PM
Frank C. Bowman
My Feedback: (13)
Default RE: Custom Piston Rings
Hello Ralph, With my tighter ring gap that is the norm if you just want to buy 1 of my rings put it in the top groove. For almost no other advantage except possibly slightly less heat just use my ring in top groove & eliminate bottom ring. My low tension rings in both grooves best and will probably take a little longer before rings need replacing. Take care & God Bless, Frank
