Custom Piston Rings
#178
My Feedback: (112)
frank could you send me your address please , i need some work done rings fitted and made. my e mail [email protected]
also if you would be willing to send me your ph no i could explane problem to you. thank you.
#183
hello and greatings from France in Strasburg.
Frank has send to me my new rings for my OS 90 SFR. Everything is ok, fast sending, perfect fabrication, engine runs smooth.
I will contact him if i have some other request for that.
If you would like the informations (adress, tel and so, thats what he sent to me)
enjoy flying
René
Frank Bowman
1211 N. Allen Ave.
Farmington, N.M. 87401-3568
U.S.A.Email: [email protected]
Reproduction Model Engine Rings Quality at a fair honest price. Making a good ring is a Skill. Making a fine ring is an Art! Last Revised 4 - 12 -14 I will reproduce nearly any model engine ring. If not available, I’ll need a good piston and cylinder to measure, or send motor. Send return postage, insurance is extra. For orders outside of USA, ask for shipping costs? Priority postage is extra. Ring cost & shipping charges for USA listed below. Please Note: If you send me an engine for new rings that I don't currently make there will be No labor charge to do this. If you send me the stripped down engine block ( Block, piston liner and rod assy.) for rings, that I Do currently make No extra charge. If you send me a complete engine to disassemble, clean, and install the ring(s) and reassemble there will be a minimum charge of $25.00 per hour. ATTENTION : NEW MEXICO CUSTOMERS WE HAVE TO CHARGE YOU 7.1875 TAX, please add the extra tax to your orders. Shipping per order in US $4.25 First Class. Priority in USA only $6.10, both with delivery conformation. For out of US shipping charges other than First Class, email for more options. Canadian Postal Money Orders Fine, US Dollars, or Paypal. If using Paypal there will be a 5% charge US Customers, 6% outside US. For Paypal payments use my email address,[email protected] or I can invoice you thru Paypal. I also accept Checks or Money Orders if they are from a US Bank.
505-327-0696
enjoy flying
René
Frank Bowman
1211 N. Allen Ave.
505-327-0696
#185
Most piston rings price for Gase engines are $10 ea.
I was asked by a customer to leave information in this section of RCU Forums. I have been a machinest all my working life and making Custon Piston Rings for approx. 12+ years for Gas, Glow and diesel engines, some motorcycles too. With my custom rings, performance will improve over nearly all factory rings because of the material I use, machining method I use and Ring gap I recomend with my rings. I use fine grained cast iron machined from solid round bar stock rough cut on OD to .010 oversized and finished with a .002 finish cut on OD for accuracy. OD of ring is cylinder bore to assure ring fit is correct and round rather than making ring larger than bore and shinking oversized ring after saw cut into smaller bore. Rings are then hand lapped to .001 smaller than piston ring land. I don't saw cut ring, I have a special tool that snaps ring before heat treat at 850+ degrees F. After heat treating on mandrels I gap ring to .001 to .002 end gap. Rule of thumb in machinest world on cast iron rings is .001 to .0015 ring gap per 1" bore diameter. I make bore gage to .0001 of cylinder bore to gap rings & ship all over the world. I make over 300+ rings and to date made thousands with a lot of happy customers. There is a lot more involved in my manufacturing process along with a lot of tooling involved, too much to discuss here. If I don't currently have dimensions to make rings for certain engines a lot of customers send the piston & cylinder to me to measure for rings & I install rings for no extra charge. I make special rings for 30 CC Homelite & 31 CC Ryobi engines that require a slight mod. of cutting anti rotation pin in ring groove down 1/2 way so my custom rings will overlap pin for much improved performance. Most rings for Gase engines $10 ea. shipped to most countries & US at $14 for 1 & $24 for 2 shipped. Discounts of $1 off per ring on orders of 10 or more mixed sizes & Brands fine. I have been endorsed many times by engine builders like Clarence Lee, Joe Wagner in magazines, etc. Email me if you have additional questions and a list of custom rings that I currently have in stock. Thanks & God Bless all. Frank Bowman at Bowman Rings. Email: [email protected]
