RE: TIP / TRICK Using EV5U-PRO Valve with 12X
Hi Guys,
I have an issue programming the 12X for brake in my jet:
I am using the EV-5U as well. Aux6 is for the brake , and for now I use the right knob for brake , just for testing purposes.
My goal is to have the brake functional when pushing down on the elev. stick, when gear is out only.
The thing is, I can only operate the brake function while the gear is in! For some reason when the retracts are out - no brake, when they are in - yes brake.
I tried to reverse the gear, or the brake - still they always work opposite.
I even connected a regular servo to the RX Aux6 instead of the EV5U cable - and still the same, so I guess it is a radio issue and not the EV5U issue.
Cna you guys help?
Zivo
