RE: gst temp question
That seems like ALOT coming out of the muffler. I also did the CA glue to the gasket to the engine. Cause everytime i put the header on the gasket would slide out. It helps. Yes 350 degrees is way to hot but I would also question the venom failsafes quality. Get a real temp gun or something. Try going back to the factory needle settings and start from there.
