RCU Forums - View Single Post - SPE 40CC Engine Problem
Old 09-29-2009 | 01:36 AM
rednekk58
Default RE: SPE 40CC Engine Problem
really can't tell you if that is your problem, but i have an spe 43 and the timimg was at aboutt 55 deb btdc. from what i've read on these forums is that it should be between 28 and 30 deg btdc. i had to use a zip tie and the some hi-temp slicone. tell us what you found. good luck.
