RCU Forums - View Single Post - TREX 250 CLONE
Old 09-29-2009 | 09:51 AM
dude7422
Default RE: TREX 250 CLONE
rcmodelpart is rite i was so happy it has come after 200 days i dont see the not 3d
copy paste from hk thanks again rcmp
Modeled on the famous and proven T-Rex 250.
This is the base model HK-T250 and is an exact clone of the T-Rex 250.
In standard trim this kit is ((((((((not 3D capable due largely to the Nylon blades))))))))
included with the kit.
The HK-T250 is an excellent way to hone your skills on a smaller more nimble machine.*
Spec.
Length: 430mm
Height: 187mm
Main Blade Length: 200/205mm
Main Rotor Diameter: 450/460mm
Tail Rotor Diameter: 108mm
Motor Pinion Gear: 15T/2.2mm
Main Drive Gear: 120T
Tail Drive Gear: 28T
Drive Gear Ratio: 1:8:4.25
Weight(w/o power system ): 138g
Required items.
Brushless Outrunner Motor
Servos
Gyro
Receiver
ESC
Lipoly Battery (800mAh 3S)
*Freakazoid indoor 3D champions can get their Snap-rolling freak on with our soon to be released HK-250GT.
