RCU Forums - View Single Post - Laser aiming device
Old 09-30-2009 | 10:33 AM
starskey's Avatar
starskey
Default RE: Laser aiming device
Well
all you do is take two turret rings and tie them together flat side to flat side with the two lugs offset to each other
carefully grind the two lugs out making sure you don't damage the teeth on the other turret ring.
and when you put them back in the tank you have a 360 turning turret.
!!!!Watch that antenna twang now!!!!
Jon
