Steve I think most of it should be straight foward. Hopefully a look through the Impact and Integral manual will guide the similar areas. Hopefully Bryan and Jason will chime in if an area is in question. I supect that several of the carbon fiber balsa pieces are used for a fuel tank mounting and are probably not used in the electric version.
Ryan the vent holes in the cowl are cut out. Exhaust vents need to be cut for the electric version. I find it a bit strange that the belly pan is mounted but not the canopy. Wing and stab tubes are mounted. No incidence adjusters on either.
I hope they followed Bryan's directions
Stuart C.
