RCU Forums - View Single Post - Phoenix Extra 330 elevator servos?
Old 10-01-2009 | 08:27 AM
da Rock
Default RE: Phoenix Extra 330 elevator servos?
ORIGINAL: hulio516
Will futaba 3004 standard servos work ok on the dual elevator hookup?
And also, if you used a dual servo reverser for the elevator which make did you use?
hulio
So? how heavy is the Phoenix Extra 330?
When the model is described with a percentage, a couple of standards (one for each elevator half) probably aren't enough. In any case, the assembly manual should offer a suggestion.
A couple of standards should be ok for any that take less than a 1.50 glow.
Taken from a thread on RCU here about that model.
.................. Im running HS-5475HB standard digital servos on elevator and ailerons and a HS-5985MG on rudder.Ive put eight flights on her now and its an awesome combination,............
