RCU Forums - View Single Post - JR 9303 Programming Help Needed
Old 10-01-2009 | 05:58 PM
STKNRUD
Default RE: JR 9303 Programming Help Needed
Hmm, sorry just remembered how I did it.
Selleri,
How do you mix the nose with the gear to disable the nose when retracted without that also disabling the rudder if the nose and rudder were connected through a MatchBox?
I know there are "magical" ways to do things with it that aren't described in the manual. For some reason, even when you INH AUX4, it (and only it) can't be selected in the Mate function of the "Wing Type" menu. Several have confirmed they can't do it either and Horizon doesn't have an explanation except to acknowledge you can't.
Yes, I could get away without the gyro but I still couldn't assign a separate channel to the Nose if I assigned my second Ail to AUX2 or AUX3. That's because I want to use the right lever (AUX3) for the brake. That would leave AUX2 for the second Ail and nothing for the nose. Only AUX 2 and AUX 3 allow you to select the right lever.
