ORIGINAL: w8ye
A friend has one that has the tail wheel wire going up into the rudder.
The main gear was just moved to the front using the 1/4'' plywood doubler behind F2.
I did one a few years back and built up a lower place under the horizontal stabilizer to look like the skid that comes with the ARF but big enough to mount the tail wheel bracket. I ran the tail wheel wire up into the rudder.
When moving the main gear to the front, do you need to use Blind Nuts for the screws to go into? Or can the screws just go into the 1/4" ply?
