RCU Forums - View Single Post - Wing incidence
Old 10-02-2009 | 10:20 AM
ppkk's Avatar
ppkk
Default RE: Wing incidence
ORIGINAL: ArcticCatRider
It's a fully symmetrical wing. With the horizontal stabilizer parallel to the horizon, I'm pretty sure the incidence of the wing is zero degrees. I will double check the plans, as well as with an incidence meter. If it's anything other than zero...it'd be 1 or maybe 2. I cannot see 3-4.
Thanks, I am planning on doing the same today. The wing fits the saddle but there are some gaps, so I want to ensure I haven't placed the dowels incorrectly as to change the incidence somehow. I don't think this is the case, but I thought it would be better to check and fix anything that could be wrong now. I'll post the results later after I have checked it with an incidence meter.
