RCU Forums - View Single Post - Wing incidence
Old 10-02-2009 | 11:42 AM
ArcticCatRider's Avatar
ArcticCatRider
Default RE: Wing incidence
Where are the gaps? If they're both up toward the leading edge...then you might have a little negative incidence. Remember you can only be off in one direction, unless you hacked away at the wing saddle.
If there aren't any real gaps from the trailing edge to the main spar...you're probably in good shape.
