RCU Forums - View Single Post - Question on painting procedure
Old 10-04-2009 | 04:47 PM
Taurus Flyer's Avatar
Taurus Flyer
Default RE: Question on painting procedure
ORIGINAL: crashlander
OK Guys here they are:
I decided to paint all surfaces first with a base coat of white. I will then lightly sand and look for any imperfections which hopefullly will be fixed. The plane has some white on it , so I will give it a final coat of white concenytrating on the areas where the whit will be.
Crashlander,
This, I do not understand (bold), are you going to paint first dark(er) colors and the last color on some areas will be white? I am afraid you will see the dark colors throught the last white if you did not mast the dark areas eccact? (am I clear?)
I think starting with white and finish with the darker colors ( when I understand your explanation?) will do better then I do not have to mask the white.
Any comment?
Cees
