RE: Composite-ARF Integral, kinda build thread
I've taped long carbon rods to the upper surface of the elevators so that they meet in the middle aft of the rudder. If the rods are straight and point exactly to each other then the elevators are line up. You can also use this to check that the elevators move together for the full range. This is much more accurate than the best deflection gauge.
Colin.
